So I was digging into my leaky front main and someone let the lower timing cover seal slip out of the groove, causing the timing cover to be too tall (by 1/8" or so) and the crank pulling, water pump pullley etc wore deep grooves into the plastic, the crank pully actually rubbed on the head of the bolt that hides behind it... So I need a replacement lower cover. I would appreciate it if the cover could come ASAP! PayPal Prefered for quickness!
Thanks!
Aaron
Thanks!
Aaron
