I know this might be a long shot but im looking for a gas tank in good shape. Mine is all rusted and all the studs for the pump assembly all broke off.
I have one. Sadly I am out of the states again and wont be back until early April, at which point I will begin the partout. I live in the springs too, so no shipping woes. PM me if your interested.
You can repair the studs. I drilled out 3 broken ones of mine and put in 5 mm(6 mm maybe?)bolts from the inside. JB welded them (not the regular JB weld, but I forget what it was called) to hold them and seal them in. Works fine because that is a really low torque nut application.
