Also note this is just for the hub itself. The little round piece that the brake rotor slides onto with the wheel studs pressed in, not the entire knuckle assembly. I noticed you said you needed the driver's side, the hub itself can go on either side. Just wanted to clear that up before you sent the payment.
A medium flat rate box for $12.35 will be the fastest/cheapest I'm sure since you're so far away. Do you want me to grab two hubs in case you ever want to swap the other one and have a matching set? It won't be any more to ship two than one.
