WTB: factory radio
Rrohde84
Active member
Mundelein il
Does anyone know where I can get my radio repaired or where to buy one trying to keep the car as factory as possible
You can contact these guys. They used to be and maybe still are the factory repair facility for Mitsubishi dealers.
RAdio repair
I have a 91 stock radio. I forget, what year do you have?
Do you know if your trunk amp is good? That is what often fails on 91s because of water intrusion.
I have a 2 DIN cassette equalizer radio (green lighting) that works. Volume control needs some cleaning, and cassette mech sticks a bit. If interested. It might be from a 92 though, but that will work without the amp.
Rrohde84
Active member
Mundelein il
I will have to look at that. The radio has very faint volume from the rear speakers. The kid who had it before me said something happened when he put one of those tape adapters in the tape deck but who knows.
The 91 factory radios (at least the CD version, 2 single DIN) uses the amp for the speaker outputs. If the amp has bad circuits, the radio may be fine but the sound output no good.
Rrohde84
Active member
Mundelein il
one thing that I noticed while playing with radio is that when I put the fade all the way to the front speakers and start to move it back the sound comes in for a second then comes out the only speaker that seams to work all the time is the right rear. unless the fade is all the way to the front. I had trouble loading a picture of the amp last night but it was mounted right by the rear speakers.
kdott96
Valley Stream, NY
I recently changed all 6 speakers in the car, and unless I did something wrong on the rear speakers they are relatively weak in sound compared to the front, they work but are just very very weak
