WTB: drive shaft center carier/bearing
PreskitVR4
Prescott, Northern AZ
go to the dealership. thats not really a part you will find used. that is a pressed fit bearing, most of the time those come apart in many pieces.
transparentdsm
Cherry Hill, NJ
you can get a nice rebuild kit for a 1g dsm from jnz tuning here i a link click 300 bucks i think. best price you'll find. plus if your changing the carrier bearings you might as well do all your u-joints because they are just as old. also if you doing this to get rid of the wub wub noise, check the balance on your rear tires first and also check your wheel bearings.
transparentdsm
Cherry Hill, NJ
here is the how too click then go to drivetrain scroll to the bottom and click the U-Joint/Carrier Bearing Drive Shaft Rebuild link and it will do a step by step for you.
turbophein
mass
i have a whole driveshaft with a new carrier bearing installed, never used after that
$150 for the whole driveshaft
nrvous
Penfield, NY
I have 2 carrier bearings and I believe all of the factory bushings to mount them. $80 you get it all.
Stephen
holeshotmoe
VA
I need one of those bearings. If still available, pm shipped price to 17268. Thanks
