WTB: down pipe
Boos929
Active member
Mass
as the title states looking for a down pipe preferably a 3 inch have a 16g I will be installing with a evo 3 o2 housing
citymunky
Chesapeake, VA
I have a 1g AWD 3" Pacesetter Downpipe, it has the wideband bung weld in near the transfer case so you could remove the sensor from the engine bay or under the car. The only thing is is that you will have to most likely reweld the flange on your CAT since I had a 3 bolt flange that connected to my magnaflow hi-flow cat.
