WTB: AWD 6-bolt flywheel options
maroonmetallic
central WI
Just like the title says, I'm looking for some oil cooler lines for the '90 oil cooler set-up. FOUND
Also interested in finding trunk interior trim (both sides) FOUND
As well as a usable factory spec or lightened flywheel.
Post here or PM me with what you have.
Thanks!
-Shawn
maroonmetallic
central WI
FWD & AWD trunk trims are different (on the inside side pieces anyways).
I know the one side has the jack on AWD Galants. The jack is typically stored with the tire on the FWD variety.
Im thinking the back carpet piece can be made to fit IF it IS different, but I have that & the trunk sill plastic already.
Thanks!
-Shawn
GSNT
Louisville, KY
I'll check out the shape of the trunk pieces in 430/1000 on Friday. If they are decent, I'll be willing to send them up to ya.
Rausch
Cleveland, OH
I have a fidanza that is in good shape. Decent amount of heat spots, but straight and smooth, worked perfectly when removed. That work? Feel free to make an offer cap-i-tain. /ubbthreads/images/graemlins/smile.gif
Quoting maroonmetallic:
Trunk pieces & cooler lines are found.
Looking for a flywheel options.
Have a stock flywheel available. Will need a light turning or just disc it for rust removal.
Alex
Alaska
Hey man I have a cherry aftermarket flywheeel with less then 20 miles on it.
I have a nice stock for sale in the fs section asking 40 shipped and paypaled.
thanks
Jesse
