WTB: 4 wheel sterring rack
Nebraska
Lincoln, NE
I'm getting ready to swap a 4 bolt subframe into mine next month. You can have mine for $75 with diff and axles. Needs picked up though.
transparentdsm
Cherry Hill, NJ
do you know where its leaking from tony? if its not coming from the boots then we can fix it. each line that threads into the rack has a rubber o-ring on it. after 25 years they go bad. i actually have to do mine soon.
1307nv
Active member
Sparks,Nv
Shane yea I know where is coming from, it's leaking from the drivers side boot and both boot are torn. The hard lines look good, but it's starting to leave an oil spot every now and than. When are you doing yours?
