WTB: 1G Engine Lifting Brackets, J-Brace (Intake Manifold To Block)
BluFalcon
Wichita, KS
Looking for a set of Engine Lifting Brackets for a 1G or GVR-4.
The 3 Point Black Brace that goes between the Throttle Body and the CAS.
The Silver Bracket that mounts to the Exhaust Manifold Flange and the Timing Belt Side Motor Mount Bracket.
I'm also looking for the "J" Shaped Green Bracket that mounts under the Intake Manifold to the Block.
If you have these, let me know. I'd prefer to use this stuff to remove my engine, rather than making something..."work" to do it.
Thanks!
Ed, I have at least the front bracket,may have a CAS bracket as well. I can check if you don't have them lined up already.
