WTB: 14b coolant lines
BogusSVO
Pensacola, Florida
This look right?
I have the tube with banjo fitting, one banjo bolt w/used washer and the o2 housing.
Package deal on it all...
I have no Idea what its worth, but its taking up shelf space. It needs a new home. Yours will do nicely! /ubbthreads/images/graemlins/laugh.gif
Shoot me what you think is a fair price on it. It will have no issues fitting in a USPS medium flat rate.
89Mirageman
Stantonsburg, NC
Almost positive that top one is correct. If it fits a 16g, it'll fit a 14b too. The other one I need has a hole for a banjo bolt on one end and a male threaded fitting on the other end that screws into the water pipe that goes from the lower radiator hose to the water pump. Think you have that one laying around too?
BogusSVO
Pensacola, Florida
Looking through some pics I have of parts, it dose not look like I have the water pipe you describe. IDK maybe a stick pipe from the the water pipe threaded fitting and some rubber hose if you can not find the OE water pipe?
