WTB: 10an return line
Jdjxr
Member
Lake City FL
I'm looking for a complete set up if possible. The 10an line and 2 fittings for the turbo to oil pan return line. Shipped to 32055. Thank you.
slugsgomoo
Tacoma, WA
depending on the manifold and turbo you have, the drain will need to be dramatically different. Also is your pan fitted for a -10 or are you looking for something that bolts on like factory, or are you using an adapater?
Mine is welded on which is nice (and leak free) but i went through multiple attempts to build a drain that worked for my turbo & manifold setup.
Jdjxr
Member
Lake City FL
I have an Evo 3 exhaust manifold and 16g right now. I would need the fittings to bolt to the oil pan. It's all still factory setup.
pot
Fayetteville, NC
Based upon what your looking for I would kindly recommend you visit extremepsi. For $64.95 you can get a brand spankin new -10 AN return line pictured below:
Extremepsi's website can be found below:
Extremepsi
Good luck brother
