Wiring info, eco/pwr switch
slobra
Wilmington, De
I was thinking about using an eco/pwr switch as a high/low boost switch for my greddy profec b. If anyone has info of what wire is what I'd greatly appreciate it.
slobra
Wilmington, De
Really? I just bought a multimeter the other day, so I'm still learning on it. I'm not very knowledgeable with electronics but I'm learning. Maybe this should be moved to the newb section /ubbthreads/images/graemlins/banghead.gif.
I use the one in my car to turn on and off the methanol injection kit. I will have to look at the wiring when I get home. Iceman emailed me a wiremap for the switch, but I ended up using a multimeter anyway. It's pretty simple.
mitsuturbo
Near Seattle, Washington
i used to use one of those switches for a dimestore antilag device
with launch control on a keydiver chip, i'd wire that switch to the timing terminal under the hood. stutterbox at 5000, hold timing at 5*btdc with the button, release and launch with 14psi
Made for some 1.7 60's on very crappy street tires. /ubbthreads/images/graemlins/laugh.gif
Hector on the board did it to his turbo xs dual stage look for him (805vr4) hell tell you what wires he used
I looked for that diagram again when I saw this post, but I can't find it.
Quoting turbowop:
