Will this Evo 3 radiator fit?
Chicago1
rio rancho nm
I was looking at some older threads about radiators and all the links to the pics where no good. I also did a search and found some info but not what I needed and I wanted to double check before ordering. I'm getting the old girl back on the road and I'm missing the radiator. Will this one work? evo 3 radiator From my understaing of Vman911 how to here radiator install all I need to due is lower it a tad and tap for a new sensor is this correct or is this for another radiator? Thanks in advance.
MX4
New Zealand
Early evo radiators are a little shorter in height than our VR4 ones. Only marginally though. I believe the inlet and outlets match up. I cant be sure on the sensor ports etc.
