where to buy cyclone intake gasket?
Boostin21
Wisconsin, USA
i might be using a cyclone intake manifold, and the gasket was busted up on it. so if anyone can help me find one or two gaskets that would be great.
thanks
Boostin21
Wisconsin, USA
thats cool! thank you. i figured he had them but with limited time i had no time to browse a site just post a question here.
ken inn
krum texas
i had to make 2 sets. not very difficult, but it does require a lot of patience. then, i coated them with hylomar. i even reused them. a thin coat of hylomar on the factory gaskets makes them easily removed, and reuseable. i also used the hylomar on both sides of the valve cover gasket, excellent seal, really long lasting, and very easy to remove.
ken inn
krum texas
you dont want it to stay together forever. you want it to seal, but be easily removeable. when installing the cyclone, it is way easier to take it apart, install the part that bolts to the head, then assemble the rest. unless you got a couple extra joints in your hands/wrists.
A mess load of patience. JNZ has not set me my cyclone gasket, its been over 6 months. /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/bawling.gif
