Wheel bearings
I was wondering what wheel bearings everyone has used and which bearings are the "best". I'm looking to replace all four and am wondering if it's best to spend the money on Mitsu parts or if aftermarket is better.
Just about all brands are good. The most important thing is to use a really good grease in there to keep the bearings alive. Rock auto can hook you up.
does anyone make a heavy duty bearing? What about the rears, do they come as a hub assembly or need to be pressed like the front?
