Wheel bearing
gvr4me
MO
I'm in the process of changing out of wheel bearing in the rear and bought a wheel hub assembly from Autozone. I did few searches on here and on DSMTuners and it looks different than what I have. Did I get the wrong thing or do I have to order the bearing from Mitsu? Anyone has done this before please chime in. Thanks.
TylerAdamson
Iowa City, Iowa
I just went through this and that's a rear wheel hub assembly for a FWD. As per my searching you can't buy the entire hub assembly for the rear. Only the bearings are available.
89Mirageman
Stantonsburg, NC
^Yep, that is the rear hub for a fwd galant. I have two perfect front hubs from an awd expo with abs. They are 4 x 114.3 as well and should be identical to the galant ones.
Terry Posten
Davenport, Iowa USA
You can get a complete rear hub w/bearings from JNZtuning.com. All OEM parts.
If I recall correctly, they are around $175 each but call them and get a quote.
jepherz
KC, Missouri
I'd just get whatever from rockauto, you can probably end up spending less than $60 for each side in the front. Bearings are all made by only a few companies anyways.
gvr4me
MO
Alright, thanks guys. I'll order new bearings from Rockauto.
