So summer is here and it's time for new tires on the summer wheels. I'm running a 17x7 with a +44 offset and 205/45/17's right now. Would it be advantageous to run a wider tire? I was looking into a 215 or potentially 225, but was concerned with the additional weight (1-3 lbs per tire) and the additional stress on the sidewall. Is it worth the extra weight and 10-20mm gained? I've searched around and found pros and cons for both and was hoping for some insight from those with similar experience.
