What is the Best Way to Remove motor mounts
gramkrakr89
Bunker Hill, WV
the hacksaw method works great if you're patient and careful... used it myself.
The idea is to chuck the mount in a vise, slip a hacksaw blade through the inside of the mount, tighten the blade back on the saw, and cut out the majority of the rubber. Then carefully cut the metal sleeve around the original rubber until it gives way. Be careful not to cut into the outer mount. You can then remove the inner sleeve w/ the rubber with a hammer + chisel or whatever.
I'm sure there's a decent writeup about it somewhere. Its pretty straight-forward, and if I can do it, anyone can... /ubbthreads/images/graemlins/grin.gif
Vr4junkie
Some wack town in CA
ok i might just have to try that method I was going to try to use a torch and burn it out but might be a little messy I might just wait and barrow my friends Hack saw
gramkrakr89
Bunker Hill, WV
yeah, the rubber comes out much easier by burning, but you still need to cut the inner sleeve that the rubber is attached to.. I just soldiered through without burning and used plenty of cutting oil for the inner sleeve (WD40). It didn't take long..
Then you can use the vise to press the new bushings in, too. ( This is pretty much required for the front mount, since it's not split.
good luck!
