I'm running Ross .020 over 8.5:1 pistons/rings/pins, and eagle rods. I am also running arp hardware, as yall know. I am definitely having the head resurfaced and I will scrape down the block with a blade and slapping a straight edge to it to make sure it is perfect; which I assume it will be.
My question to all you is simply what head gasket should I run?
Cometic MLS .(75bucks here cometic mls ) or a
4 layer Ralliart (150bucks here 4 layer oem mls )
or a basic Organic hg for 53bucks JNZ TUNING ....I probably will use copper spray with my final choice.
...and why?
...and why?
