What connector is this? Near rear end of the car....
alansupra94
Wayne,NJ
There is a picture of the clickable thumbnail to it. Basically its this connector that is kinda of near the fuel/brake lines (when they are all in a line moving towards the back of the car) and then goes into the car through this rubber grommet. Looks like there are 2 of these connectors (possibly one for each side /ubbthreads/images/graemlins/dunno.gif) as I noticed that there are 2 wires going into the grommet.
The grommet is located kinda below the center of the car, heading up towards the rear seat.
As of now, I can't seem to find a diagram of it.
Reason I have a interest in it as it is broken but the other side is not.
raptorWagon
Oak Harbor, WA
ABS Sensor, there is one on each side. You will see a sensor on the top of the rear hubs right below the e-brake cable if you follow those wires back to wheel. Is your ABS still hooked up?
alansupra94
Wayne,NJ
To my knowledge the ABS is still hooked up. The 4WS is removed but all of the ABS lines look intact.
I guess I will be fixing that sensor. Car has lot of sensors messed up.
ABS is not connected. Both fuses at the battery are pulled, all 3 connectors at the abs motor are pulled and the brain in the trunk near the antenna has been disconnected too. From what I understand the PO to me put a non abs 5 lug conversion on the car but he never bothered to disconnect anything and the ABS light was always on. So I disconnected everything else to clear the light.
alansupra94
Wayne,NJ
What is wierd is that if the donor car was from a 1993, those AWD hubs SHOULD have ABS.
I will be looking into the car more and I will let you know what I find.
curtis
Clarksville TN
Count the teeth on the hubs. Seems like the disem hubs have a different tooth count. I had an extra set in the shop but remember now I shipped them off to someone.
alansupra94
Wayne,NJ
Hope raised and then shot down /ubbthreads/images/graemlins/rofl.gif
I might just end up trading these hubs off for the original 4 Lug hubs with ABS and just having my dad's welder/machinest convert it to 5 lugs.
Haven't exactly decided on a plan as that GVR4 would have to be a 1992 for me to utilize because of the tooth ratio.
