What are cheap easy mods I can do on my stock car
My car is all stock my plans are K&N filter and plan on doing an exhaust cut out,and upgrading my inter cooler.....is there any other little things I can do like Ecu,Maf Etc upgrade I go to the junk yard alot
yeti
san diego california
Yes definately do everything you can think of maintance wise.
Do your timing belt because you Can /ubbthreads/images/graemlins/grin.gif
But understand what supporting mods you will need first
Before adding power
2of9
IGH, MN
^^^ agreed. Do maintenance then start modding. Timing belt, water pump, oil pump, etc. Start modding after that. After maintenance, for simple upgrades, i'd say get a ported 2g manifold, o2 housing, exhaust system, evo injectors are getting pretty cheap. Big 16g upgrade if you want. As for the ECU, get the reflash from Keydiver. that should do it.
AnotherNewb
Orlando, FL
My favorite free mod is removing the restrictor from the factory boost controller. But maintenance is most important.
Lonewolf64
Birmingham, Alabama
Quoting 2of9:
Keydiver chips are NLA except to already existing customers.
Well I have most of the maintenance stuff done timing belt and water pump etc have been changed .......how would I remove the restrictor
From the boost controller???
AnotherNewb
Orlando, FL
Check vfaq on removing the restrictor. But to simply sum it up there is a small plastic piece that is in one nipple on the boost solinoid that you can remove. I have screwed a small screw into it and gently pulled it out, but be carefull if you break the nipple you'll be posting a wtb thread very soon. This mod is good for a couple more lbs of boost. I think I get 12psi after removal.
