What 5th gear set will fit in a 91 F5M33?
FlyingEagle
THE Ottawa
Jacks site says FWD 92-99 and all AWD as compatible for the taller 5th gear option of the EVO3, so this means FWD 92-99 and all the AWD 5th gear sets should work interchangeably for F5M33 FWD's and AWD transaxles.
So, will this work in a 91 F5M33 ?
I have a chipped tooth, need to know the options as I have many options lined up locally and stateside.
Cheers,
Tim
EMX5636
Bucks County, PA
They all should* physically fit. I say "should" becuase I know they are the same fit to the shafts, but I don't have a FWD to test the case clearance. I'm pretty sure I threw an AWD 5th in the wife's old FWD 1G because it was laying around and didn't grind 5th gear. Some years (I think 89-90) had a smaller diameter hub/sleeve, which will work, but you will need the matching 5/R shift fork.
The AWD 5th is a little taller though IIRC.
FlyingEagle
THE Ottawa
Good to know. I will see about sourcing a local AWD 5th gear set. Would be nice to drop some RPM, but putting in a F5M33 will drop my RPM's across the board for every gear versus the KM210. It was meant for the high strung 4g61t setup, and I am now running the 4g63t in my C53a Colt. Well anything to save some fuel when the car starts getting routine fill ups with 94 (and minimum 91).
Thanks for the help, as that clears up the issue I was trying to confirm. Shaft diameter/shifter rail and fitment via the early models 89-90, verus 91+.
