tektic
I only have about 1200 miles on my engine build and the head gasket is wet and seems to be seeping coolant. I'm using a mls Mitsubishi gasket installed dry on two freshly machined surfaces.with arp studs arp lube and 90ft lb if I remember correctly.
Was I suppose to retorque the studs after heat cycles or something?
Car never over heated. no coolant in the oil. I don't know what to do right now. Should I be pulling the head the engine or just try to torque it down more?
