BagelBoy
Member
So got a weird issue going on that I figured the wizards here might know. I recently swapped my fuel lines to -6an PTFE fuel lines, and installed a new DW fuel filter 10 micron and its size is 110mm with -6an fittings. I also installed the -6 an bulkhead fitting from STM at the hanger so its all ready for my future e85 swap. Now I get a weird stutter in 5th gear where its cutting in and out before 3.5k rpm and I get a lot more knock throughout the gears. I verified my spark gap on 7es at .028, compression test is 140 across, BLT was fine at 30psi, base timing was still good at 5 degrees, and my AFPR is holding at 43.5 with vacuum off. I didn't have this issue before swapping (I had a very slight knock but it was ok at 2 degrees full WOT around 7.2k rpm) but now it fills up to around 5-9 degrees knock on ecmlink. Basically I am stumped on what else to go through and was hoping if anyone here had some directions for me to go. I believe its fuel related but I am really stumped as it shouldn't have affected my setup that drastically and everything isn't leaking and my pump seems to be fine still. Thank you guys!
