AuSpecVr4
Hey
Im thinking of upgrading my water and oil lines on my TD05 but i want to hear peoples recommendations first. The Solid lines and banjo bolts do my head in because its a pain to install the turbo and take it off. The bottom water return that goes under the turbo and is a U shape is a m14 1.5mm on both ends and i was going to replace it with 8AN line, is this overkill or should i stick with the 6AN, also doing the same for the oil return, 8 or 6an? i have already ordered a oil feed line and i figured i could make the rest cheaper.
Also i hear steel braided lines, with contact with anything or not mounted properly will rub through anything? has anyone got some pictures of their install to remove the factory lines and stop them from leaking?
Cheers, Brock
Cheers, Brock
