Hi,
my ZR4 has 4 bolt rear axles with a locked viscous LSD and is running RWD. I am wanting to fit a mechanical LSD from a Evo 2/3 and need to know if the inner cv cups for a viscous diff with the 1 side longer than the other will fit in a mechanical diff? If not is it possible to cut the viscous 1 down to fit and machine a groove in it for the C clip to slot into?
Thanks in advance.
Thanks in advance.
