I got a plx m300 wideband and I want to use it as my main front o2. How do I go for that? Anyone got a link. Have link v3 for tuning. Which wire on the ecu do I hook it up to?
In short, if you're supplying "FrontO2" with an NB signal (from the LC-1), NB simulation is not required in ECMlink. If you're using "FrontO2" as the input for logging your wide-band, then NB simulation needs to be enabled, and the NB output from the LC-1 can be ignored.
