Upgraded front brakes?
talontyme
Portsmouth,VA.
On my 91 vr4 I have a set of te37's(16x7)42 offset I believe and I want to know is there any big brake upgrade for.these.wheels.
BluFalcon
Wichita, KS
I installed a Baer Track Kit on my car recently and they barely cleared my 17x 7.5 SSR's without any mods or issues. I can try to verify the offset for you, as I don't recall exactly what they were off the top of my head. I know the Baers are a lot more forgiving as far as fitment than the 3KGT VR-4 caliper setup.
Edit: +42 Offset
524of1000
San Antonio, Tx
I have the 3000gt SL wheels. The rear trailing arms need to be modified to fit. The 3kgtVR4 calipers clear the offset, but not the inner diameter of the wheel. The caliper will need to be milled down (if you use the Tuners nation brackets) I should be done this weekend and I'll post pics if interested...
thecman02
Kalamazoo,MI
A guy on T00ners sn KVM makes brackets. Requires minimal machining/grinding, and correct offsetting to work.
