Two minor annoying problems (radio and seat related)
CarRacer
Shakopee, MN
I have noticed two minor annoyances driving my car the past few weeks.
The first is radio related. I bought a radio gauge panel and finally mounted my wideband gauge. The problem is that I now notice slight radio interference when I listen to AM radio. Anything I can do to help combat this?
I also noticed when I'm rocking the 4/60 air conditioning (4 windows down at 60mph) the armrest in the back seat flips down. Is that a common issue?
Thanks for the help.
I love the automatic rear armrest that flips down at freeway speeds. /ubbthreads/images/graemlins/rofl.gif
4thStroke
Vancouver, WA
I didnt know what was going on for the longest time with that arm rest. Just all of a sudden I would hear a rattle, look back, and that armrest would be flopped down. I flip it back up, and sure enough, it would fall back down. I thought that maybe I might just be an aggressive driver. /ubbthreads/images/graemlins/grin.gif
As for the radio problem... I think your problem may just be that you still listen to AM radio.
JK. But seriously. /ubbthreads/images/graemlins/grin.gif
Another funny thing my car does at speed is open the fresh air vent on its own. Even if it's set on recirc, as soon as I hit freeway speed, it flips back to fresh air. Haunted.
Terry Posten
Davenport, Iowa USA
I also have the recirc/fresh issue. Mine always wants to go to fresh.
Now the radio should be able to be cured by taking the ground wire of the radio directly to a chassis point and do the same for the WB. I would not use the cars radio ground wire from the factory harness.
My back seat arm rest does not fall down /ubbthreads/images/graemlins/dunno.gif
tsiboy
Los Angeles, Ca
my armrest stays in place too, but my recirc/fresh lever has lost all functionality. it stays in fresh 100% of the time /ubbthreads/images/graemlins/frown.gif
SmoothCustomer
Lexington, KY
Do you gargoyles just hate fresh air or something? /ubbthreads/images/graemlins/uhh.gif I never have mine on recirc unless it's freezing and I want it to warm up seemingly faster.
cheekychimp
East Sussex, U.K.
Quoting SmoothCustomer:
Dude you are just lucky to have fresh air. If the air was fresh here I'd rock the 4/60 method. My A/C almost never gets to fresh, air pollution is that bad it is not funny.
The fresh/recirc cable needs to be adjusted for you guys that have the moving lever.
Drop the glovebox down and you can see the door cable. Pull the cable from its clip, set the lever all the way over, (I don't remember now exactly which side (fresh or recirc) to put it to), reinsert the cable, and it should stay where you put it.
holeshotmoe
VA
Quoting Hertz:
Are you guys missing the plastic cover (passthru)? My arm rest fit rather snugly.
That's probably it. My armrest falls down directly proportional to speed. My plastic cover is broken and lying in the trunk. I'll have to put it in place.
blacksheep
Urbandale, Iowa 50323
Quoting iceman69510:
did this on several of my gvr4s., although I do remember that messing with it too much can make it hard to pull on from one side all the way to the other.
