Turbonetics manifolds
89coltgt
Ste Genevieve, MO
Do these t3 manifolds have any fitment issues at all on the 4g63s as far as ports lining up or is this just a problem with the knockoff manifolds? Also, do they have any issues with cracking?
Hksvr4
NYC
The real ones crack the knockoff's crack even more.
89coltgt
Ste Genevieve, MO
How long does a genuine turbonetics manifold tend to last? I ran across a decent deal on a new unused one that I was thinking of picking up for the hx40.
i have 1 been great so far but hasnt been on long either and had no clearance issue
3rdstrikedsm
32159, FL
Quoting 89coltgt:
I have never seen the cast ones crack.
dsmless
tucson,az
I run a cast t3 mani from slow boy racing looks and spools quick on my gt2876r the problem was that I had to grind off about 1/16 inch off the turbine housing to make it clear the front balance shaft I didn't like this but it works good so the hx40 is a toss up with fitment, you might have to grind on the turbine housing to make it clear, or even the block
bazeng
Melbourne, Australia
I had one with a GT30.
There are issues with the GT30 exhaust housing hitting the block so you'll need to get a different exhaust housing (FORD). SBR knows about this issue.
Anyway, they are solid and heavy.. I haven't seen one crack either. I did have boost creep problems though so I went for another manifold.
