trans
hey guys i have a question i was just wondering if a eclipse gst or gsx or tsi tranny would bolt up to my 91 galant vr-4 and would it be better to go with the 1g or the 2g tranny if they would bolt up p.m. me with some help thaxx /ubbthreads/images/graemlins/smile.gif...
Jesh
Soldotna, Alaska
i have a built tranny and its in a 2g gsx housing so i know that one will bolt up. the starter bolt holes didn't quite line up so i just used smaller bolts. i'm not sure about any of the other trannys. i think they should, but can't say for sure.
Jesh
Soldotna, Alaska
and i think the spline is different, but that could be fixed simply by swapping clutch plates.
1941Galant
Charles Town, WV
The input shaft splines are the same between the trannies. IIRC, you can put a 2g tranny in a 1g/gvr4, but not the other way around. For the plate that goes behind the flywheel (and locates the starter), you can either swap in a 2g plate, or drill the holes out on the 6 bolt plate in order to get the starter to line up correctly.
