Ok, my question is my tie rod on the driver side has a damaged ball joint boot. The tie rod it's self is fine. Would I be ok just getting a tie rod end to just replace the damaged ball joint boot?
If just the dust boot is ripped & the joint is OK energy suspension makes replacement dust boots but the tie rod ends are pretty inexpensive, I would just think about replacing it.
Tie rod ends & tie rod end boots, both can most likely be found at Autozone. For cheap. Like 30$ is the most expencive tie rod end there so, probably like 10$ for two boots or something
