I've been trying to figure out this tach wiring issue.
I believe the correct pinout off the back of the gauge cluster is pin#13 on connector c-50 for the tach signal.
if this is correct, where do I run the wire to?
the wiring diagram I have shows that it goes to the ignition power transistor.
the ignition power transistor I have has the 1g style 6pin connector
Im looking to hook this up directly to where the signal originates from, I don't want to make any wiring splices near my ECU.
