T Stat sensor part number? RESOLVED
mk2davis
Ventura, CA
I'm finally swapping motors out of my VR-4. I'm going to need everybody's help identifying some electrical components that have been broken and wires that have been abandoned.
Off the back of the thermostat housing there is a single sensor next to a water nipple. I believe this is the engine coolant temperature switch, a/c fan condenser. Does anyone know the part number for this? When I google it, I get a variety of results.
TIA
mk2davis
Ventura, CA
Thanks Pot.
I saw this thread, and I was hoping to get a part number for sensor 4. Mine is busted off right at the hex nut, so I can't tell how many leads go to this sensor to match it up visually. This is why I was hoping for a part number.
mk2davis
Ventura, CA
Can some one take a picture of what the sensor looks like? The dealership is being less than useful.
AllanL
NV
MB439576 - switch, water temp [installed on top of thermo housing cover, #3 in pic below]
MB439918 - switch, water temp [installed on the side of the thermo housing body, #4 in pic below]
mk2davis
Ventura, CA
Thanks Allan, that is exactly what I was looking for. Now if only I can find it for less than 61 bucks!
idreamidrive
Murray, KY
Rockauto click,1992,galant,2.0l+l4+turbocharged,1206278,cooling+system,temperature+sender+/+sensor,4748
They have both the single terminal and dual terminal sensors mixed together, but they have less than $15 a piece.
mk2davis
Ventura, CA
I saw this, but didn't see any distinction between normally open and normally closed. And since the Tstat housing has two single terminal and two dual terminal sensors, it muddies up the water just a bit.
