quote:Originally posted by ken inn:
i did it on the car a long time ago. i dont remember if i removed the harmonic balancer, but i did dremel a hole in the cover. i think i loosened some of the bolts, and slid out the filter head. i believe the gasket is different, too. the bolt that is hidden under the cover is the different one. make sure you get it, or you are sol. i used the entire setup from a 90 t/e/l, and i had to make a couple of brackets, and move the p/s cooler just a tad. if you line up the cooler with the square hole on the driver's side, everything lines up perfectly. the lower cover behind the lf wheel has an opening that looks like it was made for the cooler lines. you should also tap out the other sender hole(t/e/l have 2 senders) and put an oil temp guage sender there, if you are using and aftermarket sender(i have 2 vdo) tap both holes before you install the o/f head. freakin shavings REALLY pile up. when you install the o/f head, take some aviation gasket sealer and seal the gasket to the o/f head, leave the block side dry. i think the old o/f head on my car came off with the entire gasket on it, if some is left on the motor, it might be hard to remove. Okay, a few questions. I have an auto meter oil pressure sender. Which hole do I tap in order to mount that? Why would I need to tap two holes?
Also, where exactly are you saying I should mount the oil cooler and route the lines? Which way would it be facing after it's mounted? I have no front bumper and I have a big front mount intercooler.
Last, do you have any idea what the part number is for that gasket? I was looking in my CAPS program and only saw one gasket that looked like it goes between the housing and the block. It doesn't seem to have different options depending on the year.
