swaping tansmission output shafts
Tre3zy
South San Francisco, CA
just wondering if there any site that has a write up on how to change the transmission output shafts from 22 spline to 23 spline thnx
-triz
Terry Posten
Davenport, Iowa USA
It is not that hard.
In a nutshell:
Remove the end cap from the tranny
Remove the t-case
Remove the viscous clutch and remove the ball bearing locking the shaft in place
Slide out shaft toward engine
Reverse install
Perkul8r
Mandan, ND
I ran into that when I did my trans swap in my galant. It was so simple. Just like said before, remove end case on the trans, one snap ring to remove the viscous coupler, and the shaft just slides out. But dont lose the little ball that holds the shaft in. Mine dropped somewhere and I lost it, luckily though, I had one from the other trans.
