subframe question
l8apixvw
Active member
wny nj
heres my question. can a subframe from an awd eclipse ,be used in a vr4 with 4ws? i know the part numbers are differnt but not sure why . can some let meknow if they have done this . and if it worked out ok
thecman02
Kalamazoo,MI
lol /ubbthreads/images/graemlins/applause.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/banghead.gif
Quoting l8apixvw:
They're the same except for the 4ws, dsm is 5 lug & some dsm's have a 4 bolt rear end which is stronger than the gvr4's. Make sure you get one from a 1g awd. It seems there's been a lot of people asking about this recently.
CutlassJim
Manchester, NH
Actually he's lying and they don't fit at all. You should probably sell the car.
l8apixvw
Active member
wny nj
but i still dont know if i can bolt up the 4ws to the eclipse subframe thats the real question . i know an eclpise and vr4 a pretty similar mechanicly. but ive never seen an eclipse subframe off the car. im not a retard just new to mitsubihi's.my car already has a 4 bolt in it.
NARF
Vernon ,CT
no..... and yes.
You could mount the rear rack on a 1g subframe in the same fashion as ours, you would just have to replicate the mounting attachments, at an .00 incremental level.This is assuming you have all the 4WS stuff..... and just no subframe.
That is why the part numbers are different,I doubt anyone has done that,and if done right there is no reason it wouldn't work.
DougPorcaro
Racine, WI
Quoting Garfield Wright:
Hence the 4ws system is part of the vr4 subframe.
KT
Omaha, NE
1) Make sure you get a rear end out of a 5-spd car. The autos have different gear ratios.
2) Next time search. When you come up with a question, assume you aren't the first person to have that thought about a 17-18 year old car. I would venture to guess that 98% of your questions can be answered by searching.
Quoting turbowop:
f***ing. Awesome. Graemlin. /ubbthreads/images/graemlins/rofl.gif
You can use a awd dsm subframe on a galant vr4 if you eliminate 4ws. If you do not eliminate 4ws then no as there is no mounting tab for the rear pump.
