other strut front strut tops
I think some of these responses have neglected this. Strut implies front (rear is not strut configuration. look at a Subaru if you want to see a McPherson rear strut.) and he explicitly stated front. Do not be mistaken, 2g front strut mounts do not lower or raise the car, they simply do not fit. Even if you went to the trouble of hacking a way to fit the mount in the position of our strut insulators, the shaft of our struts is too big to fit in that little hole (strut vs. shock) and, there is not a 2g mount made to accommodate camber adjust-ability because the static camber and camber curve of a 2g is completely independent of damper orientation.
Thanks for pointing me to the info that the 3g reverted back to a McPherson front. Probably because they wouldn't otherwise have been able to fit that silly v6 between the wheels. One more ambiguity about that scrap metal cleared up.
