Stock Block Galant VR4 Record
Oobie
Member
NC/SC
I have searched to see who has the record just out of general curiosity. So far I can't tell because the only person I see that is saying they have or had a stock block from what I have found was Nate. If anyone has any info that can shed some light on the subject it would be much appreciated. Thanks
Edit: 1/4 mile record on stock block.
Oobie
Member
NC/SC
Sorry I guess I should've been a little more clear. I meant 1/4 mile record. Let me edit my first post.
LIV4PSI
O-H-I-O
Quoting EHmotorsports:
That link was pointless. It is way more incomplete than the list we have here, plus it doesn't say if anything about the engines. Gizmo isn't even listed
Turbro Negro was asking stock bottom end or stock long block. My guess is Nate Crisman's old car
EHmotorsports
Beaverton
LIV4psi I'm sorry I thought people would actually use their brain and research themselves. I'm sorry I couldn't spoon feed you. I linked that and was going to update that post with more info as I found it.
Oobie
Member
NC/SC
Quoting MellowVR4:
These guys dsm ran high 9's click
Actually they hold the DSM record with a 9.2. And if you look on the left in the link that he gave us it does say engine internals. And I would think stock block/stock bottom end is the same thing. If it doesn't have the oem from factory pistons and rods it would not constitute it being a stock block for it has been machined. So with that being said no one has answered my question. I don't know what ever happened to being helpful now a days but it seems chivalry has gone out the window.
Oobie
Member
NC/SC
I have searched every known dsm/evo forum and no one states a stock block other than Nate Crisman like I stated previously.
EHmotorsports
Beaverton
Stock block would be block only. Stock bottom end would be complete rotating assembly.
Sry this is a fact not just an opinion.
LIV4PSI
O-H-I-O
EH, I was just joking around with you. /ubbthreads/images/graemlins/wink.gif
Racah15
Colorado springs CO
We are all used to saying stock block, because that's the case.. we (most)all have a "Stock" block. Regardless of internals, or whatever. When you get into other engines like an ej, or any honda engines, or aluminum block engines, even our engines, there, at times, have to be modifications to the block to allow more power. As with almost all aluminum block engines, with greater horsepower, you need a stronger/larger sleeve. This no longer becomes a stock block.
Most EJs handle 450 stock block. Anything more and the sleeves crack. No clue on hondas, but I don't mess with those. Our engines (At high HP)sometimes need to be filled. You guys have heard of filling the block? Filling a block no longer constitutes a stock block. There is also a company in australia that makes a billet 4g63 block. That's definitely not stock. haha. So in my eyes, a stock block is just that. A STOCK block. People have made over 800 hp, on stock blocks. I do not constitute a bored block not stock. If you take your engine to a dealership because of ring issues, and they do a service on it and end up rebuilding your engine 20 over, you still have a stock block. But if you fill your block or sleeve it, then you don't have a stock block.
My opinion. But that's all it is.
To me, when it comes to the 4g63, stock block = stock bottom end or shortblock. Be it JDM import engine, or the engine that's been in your car since it rolled off the assembly line.
My engine is a stock bottom end with just a hair over 140k. The pistons/crank/rods have never been removed.
LIV4PSI
O-H-I-O
Racah, EJ engines hardly ever have sleeve failure under 550whp. All that is needed for 450whp is pistons
Jesus_Negros
USA
Quoting Racah15:
Exactly saying stock block shouldnt hint to rotating assembly. People modify the block alone for power. A block is a block now rotating assmebly is crank, rods, pistons. So is your question stock block or bottomend?
