Stock Springs, Galant VR-4:
Wire dia x OD x free length: .56" x 6.86" x 14.2" (14.3 x 174.3 x 359.5 mm)
rate: 134 lb/in (24 N/mm)
ID color: orange x 2
Stock Springs, 1G AWD M/T:
Wire dia x OD x free length: .55" x 6.85" x 12.9" (14.0 x 174.0 x 326.5 mm)
rate: 146 lb/in (26 N/mm)
ID color: pink x 1
Stock Springs, 1G AWD A/T:
Wire dia x OD x free length: .56" x 6.86" x 13.1" (14.2 x 174.2 x 333.5 mm)
ID color: pink x 2
Stock Springs, 1G FWD 2L Turbo M/T:
Wire dia x OD x free length: .55" x 6.85" x 12.7" (13.9 x 173.9 x 321.5 mm)
ID color: Light blue x 2
Stock Springs, 1G AWD 2L Turbo M/T:
Wire dia x OD x free length: .55" x 6.85" x 12.9" (14.1 x 174.1 x 329 mm)
ID color: Orange x 1
Estimated Ground Control Rates: 350F/275R (or 250?) rates.
Whitelines:
Front: PN 70128
length: 12.5"
rate: 165 lb/in
lower: 0.5"
Rear: PN 83147
length: 13.5"
rate: 132 lb/in
lower: 0.7"
Fronts are Whiteline part # 80442
11" length
210 lb/in
.90" drop
Rears are Whiteline part # 80443
12" length
155 lb/in
1.32" drop
Stock Evo 8:
Evo: 180lbs f /225lbs r
Motion ratio:
GVR4: .92 f / .844 r
Evo: .92 f / .75 r
Wheel rate of Evo springs:
GVR4: 152lbs f / 160lbs r
Evo: 152lbs f / 126lbs r
I've heard that using springs ~ 30%-50% stiffer than stock will lead to blowing out the AGXs.
1G AWD DSM springs are slightly lower in back, but taller in front. You can use 2G rear upper mounts to make it level. (2G rear mount is about 1" taller)
The best spring for the money to lower your car is the H&R set. They are Galant VR4 specific and lower 2 in the front and 1.5 in back.
Whitelines are said to be the best for fitment and height (lowered), but these may be NLA.
The Evo 8 suspension setup requires some fabbing.
The Evo 9 suspension setup (may require drilling of front knuckles to accept larger dia bolt) is pretty comfortable, and I think approximately stock height.
Most people who are serious about suspension recommend contacting
Larry Parker for a Hotbits coilover setup made specifically for the VR-4.
