Hey guys,
Im in the process of replacing my transmission, and just figured out that eh trans i just had built will not mate with my T-case. /ubbthreads/images/graemlins/banghead.gif I counted the splines on each and it looks like the output shaft has 23 splines, but the T-case looks like it is for a 22 spline output shaft.
When I had the trans built and i gave them the info on my car (model, manufacture date, etc) and they made me a trans accordingly. I am trying to figure out if they screwed up and put in the wrong output shaft, or if the T-case on my car has been changed.
I've searched for spline count on every forum I can and ive heard different things. Talking about AWD transmissions, apparently all 90's and earlier have 22 spline output shafts from the trans to the T-case. Now ive heard different things about the 91+ spline count. Here are the two things i have heard.
1) all 91+ AWD transmissions have 23 splines
2) "early 91" AWD transmissions still have 22 and the rest have 23 splines
Anyone know for sure when they switched over to the 23 spline Trans and T-case? My manufacture date is july 1991. I need to know if that car came with a 22 spline or 23 spline output from the factory.
Thanks in advance
Thanks in advance
