citymunky
I have a small 16G for sale, I was going to use it as a back up turbo back when I had 733/2000, but I don't need this since I have a 20G also sitting.
Pros:
No in-and-out shaft play.
No damage to the compressor turbine.
No damage to the exhaust turbine.
No leaky gas piston rings (aka seals).
Con:
There is no turbine housing and no wastegate included.
I do have a exhaust housing on but 20g than I can sell with this 16g, however the wastegate flapper was removed and arm was welded shut, to run a ext. wastegate setup.
Looking for $150 shipped without the exhaust housing.
Pros:
Con:
