Shaking steering wheel
My steering wheel has been having some shaking issues for a while and i cant track them down.
Things i have already done:
1. Alignment (about a year ago, but it should still be good.... i havent hit anything or messed with it at all)
2. replaced ball joints (very recently)
3. balanced and rotated tires
Things that may be causing the problem IMO:
1. the P.O. put KYB struts and lowering springs on and i dont know when they were put on.
2. i have an aftermarket steering wheel and momo adapter
4. rack and pinion
5. tie rods
The steering wheel mainly shakes when i am coasting. If i get on it hard I can't usually feel it, and when I brake it pulls a little bit one way, but no shaking so I dont think it is the rotors. I understand a little bit of shaking is normal with an aftermarket steering wheel and adapter, but this seems a little excessive. Any ideas on which is the most likely culprit and how to confirm that?
Thanks
Barnes
Richland, WA
I would start by checking your inner and outer tie rod ends. I have a bad inner tie rod end (tie rod? inner tie rod joint?) and it sounds very similar to your problem.
Quoting 92Galant926:
I'm not sure where you head this, but I have a Momo on each of my GVR4's and don't have any shaky steering wheel issues.
FlyingEagle
THE Ottawa
I would have to say that you should be getting shaking mainly from tires.
Have the tires been rotated from front to rear, and checked again?
Back in '99 or so, when 1051 was mostly stock other than some wheel/tires/springs, I went for a year with a nasty shake in the wheel and felt throughout the whole damn car. I had the tires balanced multiple times, other stuff looked at to figure it out and nothing worked. I took it back to the tire place (again) and FINALLY somebody with a brain did the balance. He realized the f***ing wheels were out of round. I got a brand new set and never had an issue again. Man that was a stupid mess.
AnotherNewb
Orlando, FL
Quoting FlyingEagle:
+1
Also if you have replaced suspension parts AFTER your last alignment then it should be aligned again. Like stated before, an aftermarket steering wheel isn't going to make your car shake
Quoting flyingeagle:
have the tires been rotated
He states in the OP he balanced and rotated the tires.
+1 on getting a new alignment after wrenching on suspension parts.
dmj
orlando FL
Could be warped rotors, tires out of balance, bad wheel bearings, bad tie rods you have to check the entire suspension/steering system.
Quoting BarnesMobile:
Inner tie rod ends? I believe the shaft just comes out of the Rack and there are only outer tie rod ends. Is that not correct?
Barnes
Richland, WA
So basically the consensus is you need to burn it to the ground and buy a brand new car. /ubbthreads/images/graemlins/tongue.gif
Quoting turbowop:
Okay, I guess shaking may not be the right word to use, but rather "feel the road" more. It is definitely shaking though so i guess the steering wheel should not the problem.
The tires are about 5,000 miles old. Had them balanced when they were installed obviously. I have had them rotated once since then, and am not sure if they were re-balanced. Maybe i should have it checked again. It should be free.
Quoting turbowop:
Ill ask the guys at the tire shop to re-balance and check my wheels. Hopefully i get a decent employee to help me when i go though.
The wheel does not shake at all while braking. Hitting the brakes makes it feel completely steady so I dont think warped rotors are the problem. Ill check to be sure the brakes are fully disengaging though.
The only suspension part i have replaced is the ball joints since the last alignment.... dont think that would effect it much. Maybe ill replace whatever else i want to in the suspension and then get it aligned.
I guess its time to just go through the system one component at a time and either replace or be sure its good.
Considered, but figured if i just built the motor and trans the suspension might be worth dealing with. /ubbthreads/images/graemlins/grin.gif
Ill look through and see what i can find. Im planning on a rotation and balance this week and seeing what happens.
The fact that is only shakes while coasting and not while braking/accellerating doesnt point to anything specific?
