Seatbelt help
My auto seatbelt on the drivers side has not worked since I purchased the car. The pass side works though. The door switch works, what do you guys recommend in testing to see if its the motor or something else?
Thank You
Muskrat
Lexington, KY
Which door switch did you test?
There's the push button switch on the chasis, but the one for the power seat belt is in the latch assembly.
Does it work when you pull the key out of the ignition, or not at all?
i did not know there was a second sensor, i tested the push one. it does not work at all.
GVR-4
Asheville, NC USA
If you need a replacement, just let me know via email. I have done the manual seat belt install and I'm pretty sure I have the old motor and some parts in the basement. They're just sitting there and all you would have to pay is shipping.
