s362 Fitment
bkaesvziank
Member
Ohio
I was wondering how hard is it to fit an s362 in a gvr4. I used to own a 1g that I ended up having to part out because I got into an accident and the body was toast. I've always liked the vr4 and I have a chance to get a pretty clean shell. The s362 fit fine in my 1g but I know that the engine bay is smaller in a vr4. Does anyone know if an s362 will fit and have a certain setup they use(no a/c, certain radiator, certain manifold)?
EMX5636
Bucks County, PA
I mocked up my setup using a S362. It's really tight compared to a 30-35R, but it is possible. I'm running a custom JMF Topmount, but they have made them for 42R's to fit. I'm running a 1G DSM radiator pushed up under the rad support a bit, with the A/C condenser also moved forward a bit. I have 2 Spal pusher fans because there wasn't room for them behind the rad.
VR4's have less room between the head and rad support, but more room up top, so a top-mount manifold will make it the easiest.
EMX5636
Bucks County, PA
I'm pretty sure that is the one that does. Mine was built as a one-off, so it's not really offered, but I'm close with the guys over there, and they know what they're doing. If you call to place the order, they usually have mock-up turbo's around so they can modify final assembly slightly to allow fitment of the big S300 cover. Just tell them what you want, they can make it work.
