tintoy
Need help. 4g63 n/a. New timing belt set correctly. Replace the tps, biss. Clean the throttle and injectors. New fuel filter. Fuel pump and fpr working properly. Timing set at 10 degrees. Still the rpm is up and down and the engine will die. Any suggestions.? /ubbthreads/images/graemlins/confused.gif thank you.
