^ Are the GM units bolt up?
Why do you say the stock alt doesn't do anything above 5k? Is there a known issue with the regulator or something?
If that's true, it would explain something I've been seeing in my logs. At cruise, I have a ~14.1v consistently. However, at WOT the voltage progressively drops up to redline. I would expect a few tenths of a volt, but at redline I'm dropping all the way down to 13.3v in some logs, which seems low to me. I'm not currently seeing any impact on performance, but I'm guessing this situation isn't optimal.
My current alternator has less than 5k miles on it. It's a factory reman Mitsu unit. I've also gone through the trouble of running a copper 8 gauge wire grounding the case terminal to a clean point on the block. Also, I have another piece of the same 8 gauge wire running directly from the charging post on the alt to the main battery fuse block, which meets the 4 gauge wire running to the battery in the trunk. This is in addition to the factory wiring, which is also hooked up to the charging post as it should be.
As a tertiary precaution, I'm also running the stock lower heat shield on my exhaust manifold to provide whatever heat shielding to the alt that I can.
After all the extra wiring , I see EXACTLY the same voltages at redline, which leads me to believe the alt just isn't putting out. I'm looking for a better alt. I'd love the buy the Denso unit G linked to in the other alt thread, but if there's a lower cost alternative that works just as well, the DSMer in me is open to suggestions.
Edit: Here's the other alt thread I was referencing:
Also, as to not turn this into another alt thread, yes, there is a voltage drop in the VR-4 just as there is the DSM. The wiring configuration for the fuel pump is nearly identical. A rewire is a good idea and the wiring is fairly easy to do. The part that sucks is running a heavier gauge wire from the engine bay to the trunk area. Unless your batt is relocated to the trunk, in which case, it's really simple. If you need help with the wiring, let me know. There is plenty of info about how to do it, but I can spell it out quickly and easily if you want.
