reverse problem??
4doorboost
Westlake Village, Cali
so i just rebuilt my motor put everything bacl and the tranny was fine. didnt rive it for about a week went to drive it today and when i put it in reverse it doesnt go in reverse it tries to roll foward? any ideas maybe low fluid? any info helps
4doorboost
i think its goin into 4th instead of reverse is there w way to possibly adjust the shifter or cables? i know reverse is good its just not putting it in reverse
TRBODSM
Northglenn, CO
Check the bolts to the shifter cable mount on the tranny, they should be two 12mm bolts that bolt it down and two more on that little mount. If they are loose or one is missing replace it and make sure they are tight enough so it doesnt happen again.
Specter
Karachi, Pakistan
Is it going into fifth gear? Yes the car is trying to go into 4th gear instead of reverse. You need to adjust the shifter cables properly. It will take some time, i had the same problem after a clutch job, senior members here helped me a lot. So give it sometime and adjust the cables, check, adjust again, recheck until it shifts like it should. You might get it into reverse and might loose the first gear. That is also the issue of proper cable setting. If its going into fifth then you only need to adjust the cable in front of the shifter. If it does not shift into fifth either then you need to adjust both of the cables.
