Replacement Radiator
Looking for some feedback on this ebay item and seller.
ebay
Anybody using this radiator? Any fitment issues?
Thanks,
Frank
I have that same unit on my car IT WAS NOT A BOLT ON AFFAIR its about 3/4 of an inch to tall the top radiator mounting brackets do not line up but the biggest draw back to the radiator is the fan switch bung is to small for our fan switch (which i still havent found an alternative for) but if you can deal with all that stuff its actually not that bad of a product i have two pusher fans retrofited from the (Nissan Titan recall) because youll have a hard time fitting the stock one back in place specialy if you have bigger intercooler pipes.
Chad989of2000
Livermore, CA
Not a fan of eBay for radiators...just google them for the car and find a decent wholesaler. You shouldn't have to pay any more than $150 for a decent one that bolts right up...unless you're a brand name hooker in which case dig A LOT deeper in that wallet.
I went with a stock replacement from rockauto.com. First impressions are good so far.
