I dont know if it is available from the factory, but Gates makes some green-stripe (i believe) fuel filler hose you can buy by the foot. We sold it when I worked at carquest and Oriellys. Just need to know approx. length and diameter.
To be honest, I have never looked at the filler hose on our cars. Flexibility depends on diameter, mostly. I seem to remember it being fairly bendy, kinda like thick, reinforced radiator hose.
I'm terrible. I took the old filler hose, and just went into the back of the parts store and found a radiator hose that was similar. Works so far. /ubbthreads/images/graemlins/uhh.gif
I bought one from JNZ a few months ago for like $23, I hear that they are NLA now. JNZ did tell me tat the breather hose is NLA though, I just ended up using some braided fuel line and clamps for that.
Quoting BarnesMobile:
Is radiator hose meant to hold up to gasoline? I didn't think it was but was going to do the same if it was.
If you have to, just replace the stock filter with an aftermarket part and replace all the ends according to what is needed on the new filter. Then tap the stock rail for an AN fitting.
The radiator hose will get all soft and gooey from the exposure to gasoline and its fumes. I would suggest hitting up a marine store and getting the hose that is used to connect boat fuel tanks to the filler on the side of the boat. It is made to flex but I don't know if its flexible enough for the bend needed on our cars. If you need a 90* bend in it you can just get a stainless elbow in the correct diameter and splice it into the appropriate location on the filler hose.
Quoting Terry Posten:
/ubbthreads/images/graemlins/ooo.gif /ubbthreads/images/graemlins/rofl.gif
Wow, I read that wrong.
I think Jeremy Clark was also having issues with this.
I took care of that problem for Jeremy a while back. It's nla @ this point as I bought (at least I think I did) all that was left in the system & they're all gone now.
I'm working on getting this remade in ss. It will require 2 couplings & 4 clamps to make it work but this has been on my list of things to have made for about 3-4 mths now. I'll keep everyone posted. I just need to get my car back off the stands & on the ground so I can take it to the shop.
I also carry -12an fuel hose that will work for the breather hose as well click me.
